Mondial RZ Nuda & Streetfighter
MONDIAL: NEW FOR 2004
Mondial can definitely not be described as a production line motorbike producer: every motorbike is individually assembled by hand, giving the certainty that everything is accurately done and then tested on in the lab and on the road by professional mechanics.This attention to detail is Mondial's personal philosophy as it aims to grow.
After launching the Piega model, at the Eicma Milan show they unveiled the Piega Evo, the RZ Nuda and the RZ Starfighter all examples of quality, aesthetics and safe handling, proving yet again that bikes with the Made in Italy label is still an a guarantee of quality.
Piega Evo is a 999cc sports bike with a twin-cylinder V 90 degree engine that produces 105Nm of power at 10,000 revs.
RZ Nuda is a naked bike without giving up the comfort of a Mondial bike and the company has announced the price will be particuarly competitive compared to other producers.
GENERAL
Model 2004 Mondial RZ Nuda
Category Naked bike
ENGINE
Type 999 cc, Liquid cooled, 90° V-twin, 4-stroke
Bore x stroke (mm) 100 x 63.6
Compression ratio 10.8:1
Valve train DOHC, 4 valves per cylinder
Fuel system Electronic injection
Transmission Chain
Gears 6 speed
Power 140 hp (102.1 kW) @ 9800 rpm
Torque 100 Nm @ 8800 rpm
Starting system Electronic
CHASSIS
Front suspension ĂHLINS type , 120mm travel
Rear suspension PROGRESSIVE ADJUSTABLE SHOCK-absorber OHLINS ON SPECIFIC MONDIAL , 120mm travel
Brakes front dual 320mm discs with radial-mounted 4-piston calipers
Brakes rear single 220mm disc with 2-piston calipers
Tires front 120/70-17
Tires rear 180/55-17
Rake / Trail 26 degrees
DIMENSIONS
Length 2000 mm (78.7 inches)
Height 1000 mm (39.4 inches)
Seat Height 820 mm (32.3 inches)
Wheelbase 1420 mm (55.9 inches)
Fuel Capacity - reserve 17 l (4.49 gallons) - 25 l (6.61 gallons)
Dry Weight 178 kg (392.5 pounds)
0.F2?OpenElement&FieldElemFormat=jpg
GENERAL
Model 2004 Mondial RZ Starfighter
Category Naked bike
ENGINE
Fuel system INJECTION ELECTRONIC
Transmission Chain
Gears 6 speed
Torque 100 Nm @ 8000 rpm
CHASSIS
Front suspension OHLINS TYPE UPSIDE-DOWN STELES FROM 43MM ADJUSTABLE TIN ON DETAILED LIST MONDIAL, 120mm travel
Rear suspension PROGRESSIVE ADJUSTABLE SHOCK-ABSORBER OHLINS ON SPECIFIC MONDIAL, 120mm travel
DIMENSIONS
Width 990 mm (39 inches)
Fuel Capacity - reserve 18 l (4.76 gallons) - 38 l (10.05 gallons)
RZ Starfighter has a special design by Massimo Zaniboni of Studio Arkema. Powerful and trustworthy, it is easy to ride but does not go unnoticed. Components and finish are top of the range.
No dla mnie cud - miód i delicje!. :twisted:
CYBER! CYBER!
Gruss!
I.
  • 2 miesiące temu...
Jeśli chodzi o zastosowane technologie, elementy, wykończenie to zdecydowanie wypas. Design to już kwestia gustu. Najważniejsze jak jeżdżą?! Jak do tej pory testy w których widziałem Mondiale(te plastiki na z silnikiem od VTRySP) nie wypadały rewelacyjnie- nie dość że konkurencja wielokrotnie tańsza była równie dobra a nawet lepsza to strasznie awaryjne te Mondiale były. Ekskluzywane zabawki jak dlamnie- gdyby nawet mnie było na nie stać to bym sie raczej nie skusił.
Rozkosz dla oczu! Ten wahacz i rama!
Pewnie, że to zabawka dla bogatych chłopców (albo synów bogatych tatusiów), ale komu to przeszkadza? Moto wygląda super i mam nadzieje, że równie dobrze jeździ (bo nigdy tego nie sprawdzę, he he).
A silnik to konstrukcja własna czy jakaś pożyczka?
