DUCATI - co myslicie o propozycjach na 2006 r....
Monster S4RS- Testastretta- Superbike
999R replica 'Xerox"
Hypermotard
Monster musi chodzic niesamowicie 'na Testastreccie' (996R, 998...), 'Xerox' mnie normalnie zabil a 'Hypermotard'...ladny i 'napakowany'-zobaczymy.
Dane Monstera:
CHASSIS
Frame Tubular steel trellis
Wheelbase 1440 mm / 56.7 in
Rake 24°
Front suspension Ăhlins 43 mm upside-down fully adjustable fork with TiN surface treatment
Front wheel travel 130 mm / 5.1 in
Front brake 2 x 320 mm discs, 4-piston 4-pad radial caliper
Front wheel 5-spoke light alloy 3.50 x 17
Front tyre 120/70 ZR 17
Rear suspension Progressive linkage with fully adjustable Ăhlins monoshock. Aluminium single-sided swingarm
Rear wheel travel 148 mm / 5.8 in
Rear brake 245 mm disc, 2-piston caliper
Rear wheel 5-spoke light alloy 5.50 x 17
Rear tyre 180/55 ZR 17
Fuel tank capacity 13.5 L / 3.6 US gal (includes 3 L / 0.8 US gal reserve)
Weight * 177 kg / 399 lbs
Seat height 800 mm / 31.5 in
Instruments Electronic panel: speedometer, rev counter, neutral light, oil pressure warning light, low fuel warning light, high beam indicator, turn signals, immobilizer system, LCD clock and oil temperature, LCD odometer and trip meter
Warranty 2 years unlimited mileage
Colour combinations:
(Tank-Frame-Wheels) (red with white stripe-red-black) (pearle white with red stripe-red-white) (black with grey stripe-matte black-black)
Versions Dual seat
* = The weight excludes battery, lubricants and, where applicable, cooling liquid.
ENGINE
Type L-twin cylinder, 4 valves per cylinder Desmodromic; liquid cooled
Displacement 998 cc
Bore x Stroke 100 x 63.5 mm
Compression Ratio 11.4:1
Power* 95.7 kw - 130 hp @ 9500 rpm
Torque* 10.6 kgm (76.7 lb-ft) @ 7500 rpm
Fuel injection Marelli electronic fuel injection, 50 mm throttle body
Exhaust 2 aluminium mufflers
Emissions Euro 3
TRANSMISSION
Gearbox 6 speed
Ratios 1st 37/15, 2nd 30/17, 3rd 27/20, 4th 24/22, 5th 23/24, 6th 24/28
Primary drive Straight cut gears; ratio 1.84
Final drive Chain; Front sprocket 15; Rear sprocket 43
Clutch Dry multiplate with hydraulic control
POWER CURVE Click here
* = Data calculated using an inertia dynamometer
close
Dane 999 Xerox:
CHASSIS
Wheelbase 1420 mm / 55.9 in
Rake 23.5° - 24.5°
Front suspension Ăhlins 43 mm upside-down fully adjustable fork with TiN surface treatment, for radial calipers
Front wheel travel 120 mm / 4.7 in
Front brake 2 x 320 mm semi-floating discs, 4-piston 4-pad radial caliper
Front wheel Y-shaped 5-spoke light alloy forged 3.50 x 17
Rear wheel travel 128 mm / 5 in
Rear brake 240 mm disc, 2-piston caliper
Rear wheel Y-shaped 5-spoke light alloy forged 5.50 x 17
Rear tyre 190/50 ZR 17
Fuel tank capacity 15.5 L / 4.1 US gal (includes 3 L / 0.8 US gal reserve)
Weight * 181 kg / 399 lbs
Seat height 780 mm / 30.7 in
Instruments Speedometer, rev counter, high beam indicator, turn signals, oil pressure warning light, low fuel warning light, neutral light, water temperature, immobilizer system
(Tank-Frame-Wheels) (Xerox-red-black)
Versions Single seat
ENGINE
Type L-twin cylinder, 4 valves per cylinder Testastretta Desmodromic; liquid cooled
Displacement 999 cc
Bore x Stroke 104 x 58.8 mm
Compression Ratio 12.5:1
Power* 110 kw - 150 hp @ 9750 rpm
Torque* 11.9 kgm (86.1 lb-ft) @ 8000 rpm
Fuel injection Marelli electronic fuel injection, 54 mm throttle body
Exhaust Single steel muffler with catalytic converter
Emissions Euro 2
TRANSMISSION
Gearbox 6 speed
Ratios 1st 37/15, 2nd 30/17, 3rd 28/20, 4th 26/22, 5th 24/23, 6th 23/24
Final drive Chain; Front sprocket 15; Rear sprocket 36
close
Z danymi Hyper...-jako Concept-Bike'a jest nedznie...
Jeśli ktoś się chce bliżej zapoznać z Ducati Sport Classic to polecam lekture grudniowego Świata Motocykli ;) Jednak powiem szczerze, że srednio odpowiada mi taki styl (a model Paul Smart 1000 to jak dla mnie porażka). Wole monstera pokaznego na fotach w pierwszym poście :-)
Niedość że piękne to i piękne wręcz cudowne :-D
Ducati :arrow: ma jedną wade 8O nie jest moje :-D
" Im więcej jeżdzę tym mniej czuję się motocyklistą " .
"The Nightrider, that is his name. The Nightrider. Remember him when you look at the night sky".
