walenie dymem
piotr8910
Nigdy nie lej Mixola bo zarabiesz silnik ja leje do swojego pizdzika moul i sie kula jak trzeba sciagnij glowice i obadaj co w trawie piszczy sprawdz uszczelke
:biggrin: elo mam honde mtx 80 i mam cylek malossi 110 nie wiecie gdzie moge do tego cylka tłok dostac rednica cylka to 53mm
tylko teraz mi powiedzcie czy do przekładni mam wlać olej 10w40 2t , czy 75w90 2t ..
bo są rózne odpowiedzi
kawałek manuala :
"General Specifications AM6chap. 2 Release 00 2000-01 2-3
2
* Alternatively, use brand name oil complying with or exceeding the specifications shown in the table.
** Alternatively, use brand name grease for rolling-contact bearings having the following characteristics: useful temperature
range of -30° C to +140° C, dropping point ranging from 150° C to 230° C, excellent protection against corrosion, resistance
to water and oxidation.
*** Only use nitrite-free antifreeze and anticorrosive products ensuring protection down to -35° C.
Ignition timing
To check the ignition timing, follow these steps:
a) Screw a centesimal comparator into the spark plug
hole.
b) Turn the crankshaft to the TDC (Top Dead Centre)
and zero the comparator.
c) Turn the crankshaft clockwise (opposite direction to
operation) until the gauge indicates value “A” (see
table and figure).
Ducati
Spark plug type electronic
85 W 6 poles
“A” spark
advance
value 1,4
Corresponding
spark 20°
advance value
Spark advance
A
d) Check the alignment of the two reference marks for
the ignition timing by inserting a Ø 4 mm pin into
the hole in the flywheel.
e) If the timing is not obtained, loosen the fastening
screws of the fixed part, rotate as much as needed
in the proper direction, then retighten the screws
and repeat steps b), c) and d).
Engine fastening tool: 8201532
TABLE OF LUBRICANTS
USE SPECIFICATIONS PRODUCTS SYMBOLS
Mixer oil * ISO-L-ETC++, A.P.I. TC++ PRO GPX 2
SPEED 2T
Gearbox oil * A.P.I. GL-4 F.C. SAE 75W – 90
GEAR SYNTH
Grease for joints, pins
and bearings ** AUTOGREASE MP
GREASE 30
Coolant *** ECOBLU –40°C
COOL
Thread-braking Loctite LOCTITE 243
Liquid seal Loctite LOCTITE 580
C
F
B
M
T"
co ciekawe instrukcja do RIEJU z 2006 też z silnikiem Minarelli AM6 zaleca 10W30
Olej orlena to półsyntetyk, i po nim motor mocno kopci.
W rs dozownik masz pod kanapą.
Wodę sprawdź w chłodnicy a nie w zbiorniczku wyrownawczym.
Spuść olej z skrzyni biegów, zalej nowy- ile masz napisane na karterze. Zobacz ile spuszczonego oleju ubyło.
do RS do przekładni 10W/30 półsyntetyk
5W/20 pełensyntetyk
Jak nie to zmien dane w profilu.
a jest 8 czy 9 miesięcy do wyboru ??:D
http://miszczua.cba.pl
