Shrek Opublikowano 2 Września 2003 Udostępnij Opublikowano 2 Września 2003 Motorcycling's 'stoppie' best raised to 266 metres Just days after being unleashed onto the UK's roads, the Buell Firebolt XB12R has already muscled its way into motorcycling's world record books. Buell's professional extreme rider, Craig Jones, has just pulled a phenomenal 266 metre 'stoppie' in the Florida heat. And the bad news for anyone chasing Jones (and his Firebolt) is that the 300 metre mark is now firmly in his sights. A skilled manoeuvre, the 'stoppie' tips the moving motorcycle onto its front wheel by squeezing the front brake, and involves travelling as far a distance as possible without the rear tyre touching down on the tarmac. As all motorcycles are rear-wheel driven, the skill lies in keeping the bike moving while braking at the same time. Earlier this year Jones set a new world best at the same Florida evaluation centre piloting a streetfighter Buell Lightning XB9S. But that 225 metre 'marker' was just a starting point for Jones, according to Buell's European brand manager Ian Bland: "Craig was virtually waiting outside the factory gates for this motorcycle! Just like the Lightning XB9S, the Firebolt XB12R has a massive 375 mm ZTL front brake with six pot calliper to deliver excellent braking power and feel which is ideal for stoppies. However, the extra grunt offered by the bigger 100 bhp, 1203 cc V-twin engine enabled Craig to accelerate to a higher speed in his run-up before putting the Firebolt on its front wheel, and that meant the 225 metre mark didn't have a chance." Jones and his Buell support team made several modifications to the Firebolt XB12R. The motorcycle's mirrors, passenger pegs, indicators and rear brake system were all removed. Motocross type bars replaced the clip-on handlebars and 30kg of lead ballast was skilfully loaded inside the front fairing to put the Firebolt right on its nose. Then it was just a simple matter of reaching a launch speed of 130mph, squeezing the front brake and steering the Firebolt down a track that had heated-up to a blistering 102 degrees. As Craig explains: "This was extreme riding in every possible sense. The track was red hot and my physical fitness was tested to the limit, the air temperature was 94 degrees and that's not fun in full leathers. "But I was always confident the Firebolt XB12R would deliver the record. Just like the Lightning XB9S it's a beautifully well-balanced motorcycle with a short wheelbase, low centre of gravity and with 81 lb ft of torque it's perfect for what I do, and for breaking world records." The Buell-Jones World Record "Stoppie" Statistics: Location: Florida Evaluation Centre (F.E.C), Naples, Florida. Date: 15 August 2003 Time: 14.30 hours Bike used: Buell XB12R Air temperature: 93.6 degrees F Track temperature: 102.0 degrees F Wind speed: 2 mph head wind Relative humidity: 51% Starting take off speed: 130 mph (208 km/h) Distance carried on: front wheel Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Hero Opublikowano 3 Września 2003 Udostępnij Opublikowano 3 Września 2003 No skubany...Co tu duzo mówić jest po prostu debeściak...gratulacje :D Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Gościu Opublikowano 3 Września 2003 Udostępnij Opublikowano 3 Września 2003 troche bałbym sie tak hamować z 200km/h 8) Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Hero Opublikowano 3 Września 2003 Udostępnij Opublikowano 3 Września 2003 Hehe, weź pod uwagę że on traktuje to 200 jak my 100 albo 60 km/h :D ja zresztą po 3 dniach jeżdzenia ducatu ST2 stwierdzam że wiele rzeczy robi się znacznie łatwiej/prościej niż w mojej yamaszce.. tyle że Ducati jest prosto z salonu...resztę trzeba dospiewać samemu... tak samo i jones ma taki sprzęt że my tylko możemy pomarzyć i od groma doświadczenia.. Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Gościu Opublikowano 3 Września 2003 Udostępnij Opublikowano 3 Września 2003 Hehe' date=' weź pod uwagę że on traktuje to 200 jak my 100 albo 60 km/h :D ja zresztą po 3 dniach jeżdzenia ducatu ST2 stwierdzam że wiele rzeczy robi się znacznie łatwiej/prościej niż w mojej yamaszce.. tyle że Ducati jest prosto z salonu...resztę trzeba dospiewać samemu... tak samo i jones ma taki sprzęt że my tylko możemy pomarzyć i od groma doświadczenia..[/quote'] przykra rzeczywistoć :D jezu a moze to matrix 8O :lol: Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
biały18 Opublikowano 3 Września 2003 Udostępnij Opublikowano 3 Września 2003 eee słabo, za rok go pobije :lol: :lol: pozdro :D Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Lukasz_SE Opublikowano 7 Września 2003 Udostępnij Opublikowano 7 Września 2003 Eeeee tam...tylko 266 metrow???Na jednym filmie gosciu jedzie na przedniej gumie ponad 927 stop czyli okolo 305 metrow jezeli dobrze licze...niestety nie moge znalezc tej strony gdzie byl film...dodam jeszcze,ze gosciu nazywa sie Matt Gorka jezeli mnie pamiec nie myli i jest czlonkiem teamu 1096 z USA.Pozdro!!! Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Hero Opublikowano 7 Września 2003 Udostępnij Opublikowano 7 Września 2003 Obawiam się że napisałeś błędnie .Np w StuntWars 2003 Matt nawet nie zakwalifikował się do pierwszej trójki w najdłuższym stoppie. Pierwsze miejsce zajął Matt Weber - 346 stóp. czyli ok. 100 m.Jest dobry, ale nie aż tak... Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Lukasz_SE Opublikowano 8 Września 2003 Udostępnij Opublikowano 8 Września 2003 Hmmm...no mozliwe ale tym filmie wyraznie przejezdza 938 stop.Znalazlem linka wiec sam zlukaj.http://www.underzen.com/videos/mattgorka.wmvPozdrowka!!! Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Hero Opublikowano 8 Września 2003 Udostępnij Opublikowano 8 Września 2003 Heh, nie wiem co tam powypisywali na tym asfalcie, ale jak na moje oko to tam było jakies 100 m. Tak się składa że sporo biegałem na 100 m. i wiem jak taki dystans wygląda... Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
AdamWo Opublikowano 8 Września 2003 Udostępnij Opublikowano 8 Września 2003 NIe wiem jak jakis tam gosc ale Craig Jones mial rekord swiata w stoppie i wynosil on do niedawna 225 metrow, jak widzac pobil go. WORLD RECORD FOR CRAIG JONES AND BUELL MOTORCYCLES Motorcycling has a new world record holder. Craig Jones accelerated his Buell Lightning XB9S to a launch speed of 119mph, applied the front brake to tip the bike onto its front wheel, and then sped down a tarmac strip for a distance of 225 metres whilst braking and keeping the back wheel completely off the ground. http://www.craigjones.com/images/Craig-rec...ec-stop-med.jpgThe 34-year old Englishman, Europe's reigning Stuntriding Champion, demolished the previous motorcycle 'stoppie' record by 62 metres and now holds one of the world's most hair-raising records. In terms of distance, Craig's feat is the equivalent of flying down the length of two full-size international football pitches balanced on just the front wheel of a fast-moving motorcycle. The record has been officially recognised by the Guinness Book of Records. "I do stoppies everyday, but not quite like this," Craig points out. "But a tidal wave of adrenaline hits you the moment you're on that front wheel and it's an unbeatable sensation. I needed to take the Buell Lightning up to nearly 120 mph, squeeze the front brake to place the bike onto the front wheel, and then concentrate extremely hard on my steering, balance and the need to maintain every bit of momentum. "It's an odd experience to be zipping down the track with the bike's back wheel spinning in thin air above your head, with the handlebars underneath you. But I've got complete confidence in my Buell and I knew we had a great chance of taking the record." Ian Bland, Buell's European brand manager, added: "Craig seems to defy most of the laws of gravity when he gets on a motorcycle. He's got a big reserve of personal courage, but what makes him special is a combination of professionalism and some exceptionally precise handling of the motorcycle. He's in total control of the manoeuvre, himself and our bikes." Craig didn't ride a specially-prepared stunt motorcycle. He simply took a standard Lightning XB9S, adjusted the tyre pressures, and then went out and broke the record. Craig, who performs around the world for Buell and Harley-Davidson, set the new world best under closely controlled conditions at a Florida evaluation centre, with independent witnesses and the Buell technical team in attendance. Craig's passion for motorcycling started in his teenage years when he used to slip out of the backdoor of his parents home to ride bikes with his friends. After graduating from university with an engineering degree he then began to develop his own unique extreme riding programme and was one of the first people to secure factory sponsorship. "Everyone at Buell is delighted with the record, but my parents still wish I’d get a proper job. It's an unusual choice of career but I love entertaining the crowds and it's great to make a living from riding motorcycles." The 'stoppie' manoeuvre is a Craig Jones speciality. The European Champion even takes a passenger on his Buell when competing against his fellow professionals. "My stunt partner Wing Chui, positions himself on the front of the bike. The highlight of the 'two-up stoppie' is when the bike pitches right forward and Wing's titanium helmet scrapes along the asphalt and the sparks fly." WORLD RECORD INFORMATIONMotorcycle: standard Buell Lightning XB9STyres: Dunlop 207Launch speed: 119 mphLocation: Harley-Davidson Florida Evaluation Centre (Naples, Fla)Previous world best: 163 metresCraig Jones world record: 225 metres The stoppie world record: the maximum distance that a motorcycle can cover on the front wheel while under braking Further information on the Lightning XB9S and Buell motorcycles can be found at www.buell.com. Additional information on Craig Jones is at www.craigjones.com. NOTES TO EDITORS: Craig Jones is a professional extreme rider and the reigning European Champion. He rides exclusively for Buell American Motorcycles and Harley-Davidson, always under carefully controlled conditions and with appropriate safety measures in place. Craig Jones and Buell do not advocate extreme riding on any public highways. Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Gościu Opublikowano 8 Września 2003 Udostępnij Opublikowano 8 Września 2003 a tak w ogłoe to fajne moto :) Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
cabaniero Opublikowano 14 Września 2003 Udostępnij Opublikowano 14 Września 2003 Jones jest mocny, widziałem w Bielawie...ale ci goście z filmiku "Wojownicy ulicy" są jeszcze mocniejsi... Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
szable Opublikowano 14 Września 2003 Udostępnij Opublikowano 14 Września 2003 a ten Jones to zawsze na Buellu? /boje sie tu uzyc nazwy HD/Co takiego ma ten motocykl, ze taki wymiatacz akurat na tym?Przeciez o ile sie nie myle tow Buellu jest nadal zwykly popychaczowy widlak?Pytam z ciekawosci- nie ze zlosliwosci:)) Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Pawel Opublikowano 14 Września 2003 Udostępnij Opublikowano 14 Września 2003 Tak, Buell ma silnik opoychaczowy, wywodzący się ze sportstera 1200. Widziałem ten motocykl wczoraj na bazarze. K**wa ale tp malutkie. Naprawdę. Wieliki silnik, a ogólne rozmiaty jak mój GS, hehehehe. Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
