Kawasaki Z 750 S Vacuometr
pitrak
Witam serdecznie !!!!!!!!!!!!!!!
Chcę wykonać ustawienie dysz w kolektorze dolotowym przy wtryskach Vacuometrm . Dane posiadam z serwisówki :
•Connect a commercially available vacuum gauge [A] to
these right fittings of the throttle body as shown.
Front •Connect a highly accurate tachometer to one of the stick
coil primary leads. •Plug:
Vacuum Switch Valve Hose (Thick) and its Air Cleaner
Housing Hole
Vacuum Switch Valve Vacuum Hose Ends [C]
•Connect:
Fuel Pump Lead Connector [A]
Extension Tube
Special Tool - Extension Tube: 57001-1578
•Start the engine and warm it up thoroughly. •Check the idle speed.
Tachometer [A] •Open and close the throttle.
If the idle speed is out of the specified range, adjust it.
CAUTION
Do not measure the idle speed by the tachometer of
the meter unit.
•While idling the engine, inspect the engine vacuum, using
the vacuum gauge .
Engine Vacuum
Standard: 29.7 ±1.333 kPa (225 ±10 mmHg) at Idle
Speed 1 100 ±50 r/min (rpm)
If any vacuum is not within the specifications, first synchronize
the balance of the left (#1, #2) and right (#3, #4)
assemblies.
Example:
#1: 165 mmHg
#2: 190 mmHg
#3: 170 mmHg
#4: 200 mmHg
•With the engine at the correct idle speed, equalize the
lower vacuum of #3 and #4 (example 170 mmHg) to the
lower vacuum of #1 and #2 (example 165 mmHg) by turning
the center adjusting screw [A].
NOTE
○After adjustment, the final vacuum measurement between
the lowest throttle valves may not be 165 mmHg
(in this example). The goal is to have the lower two vacuums
between the left (#1 and #2) and right (#3 and #4)
banks be the same.
•Open and close the throttle after each measurement and
adjust the idle speed as necessary. •Once the throttle valves have been synchronized, inspect
the main throttle sensor’s output voltage to ensure proper
operation (procedure is at the end of this section).
Nigdy tego nie robiłem i za bardzo nie jestem pewien czy dam radę, mimo to chcę spróbować.
Proszę więc o poradę co i jak oraz w jakiej kolejności warto zacząć.
Pozdrawiam pitrak :cool:
Nie bardzo rozumiem pytanie, przeciez wszystko jest napisane.
A czy masz wymagane oprzyrzadowanie, np dokladny obrotomierz i mierniki podcisnienia z przedluzkami, bo jesli chcesz bazowac na motocyklowym obrotomierzu i tanich vacuometrach to raczej ciezko bedzie o sukces.
Koszt oprzyrzadowania dla wtryskow jest taki ze zawsze wole pojechac do dobrego warsztatu i zaplacic niz wybecelowac na dobry sprzet zeby jeszcze meczyc sie z ustawianiem wlasnego moto.
