marek hd Opublikowano 10 Października 2013 Udostępnij Opublikowano 10 Października 2013 witam. mam w swoich rekach fat bob 2012 . wszystko jest ok..ale wyswietla mi sie info .. LO-RNG co to oznacza?? pomoze ktos ?? pzdr sporciak na gaziorze 1200 Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Wallygatorr Opublikowano 10 Października 2013 Udostępnij Opublikowano 10 Października 2013 (edytowane) LO-RNG - low range (krótki zasięg). Opis funkcji poniżej, niestety po ENG, ale jest google translator... :wink: Fuel Range FunctionThe fuel range function shows the approximate mileage availablewith the amount of fuel left in the fuel tank.1. With the ignition switch in the ACC or IGNITION position,press function switch until fuel range function is displayed,as indicated by the letter 'r' in the left side of the odometerdisplay. The calculated remaining distance (miles or kilometers)to empty is displayed, based on the amount of fuel in tank. Range can be accessed at any time using thefunction switch.2. When the low fuel warning lamp illuminates, the rangefeature will automatically be displayed in the odometerunless this automatic pop-up feature is disabled by a pressand hold of the function switch while in range displaymode. Automatic range pop-up feature will show that it isdisabled by blinking twice. Likewise, automatic rangepopup can be reactivated by a press and hold of thefunction switch. Range will blink once when the automaticpop-up feature is re-enabled.NOTE• When the low fuel warning lamp turns on, there isapproximately 1.00 gallon (3.79 liters) of fuel remaining inthe tank. Refuel as soon as possible.• The range display is only updated when the vehicle ismoving.3. After the range calculation reaches 10 miles (16 kilometers)remaining, the range display will display "LO RNG" toindicate that the vehicle will shortly run out of fuel.4. Resetting the low fuel warning lamp and range requiresan ignition cycle change. Na jednym z forów zaoceanu ktoś pisał o problemie z Fat Bobem 2012 i komunikatem LO-RNG przy 3/4 baku po odpięciu akumulatora. Lekarstwem jest przejechanie 5-10 mil... Popatrzyłem jeszcze na szybko, TTTM.... Po odpięciu akumulatora zawsze tak jest, znika po kilku uruchomieniach motocykla. Edytowane 10 Października 2013 przez wallygatorr Cytuj http://keeprockin.art.pl/Facebook Keep Rockin' Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
marek hd Opublikowano 10 Października 2013 Autor Udostępnij Opublikowano 10 Października 2013 (edytowane) dzieki ..za szybka odpowiedz ........ :) POMOGLO.. :lalag:pzdr Edytowane 11 Października 2013 przez marek hd Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
