RM 250
http://img146.imageshack.us/img146/6241/rmxh5.gif
1: SHAFT,CNTR
10-2: GEAR,2ND DRVN,N
11-2: GEAR,3RD DRIVEN
12-2: GEAR,4TH DRIVEN
13-2: GEAR,5TH DRIVEN
2-2: GEAR,2ND DRIVE,
3-2: GEAR,3RD DRIVE
32-1: SPROCKET,ENGINE
32-2: SPROCKET,ENG,14
36-1: CHAIN ASSY,DRIV
37-1: JOINT,CHAIN
4-2: GEAR,4TH DRIVE,
5: GEAR,5TH DRIVE
8: SHAFT, DRIVE
9: GEAR,1ST DRIVEN
14: BUSH, 20X24X10
15: BUSH, 25X28X10
16: WASHER, SHIM
[17X30X1.0]
17: WASHER
[MODEL T]
18: SHIM,22X34X1.5
22X34X1.5
19: WASHER,5TH DRIV
[25X34X1.0]
20: DRIVEN GEAR CIR
21: WASHER 4305-001
22: B1 25X52X15 BEA
23: B1 17X40X12 BEA
25: B1 22X56X15 BEA
26: SEAL,OIL,28X38X
(28X38X6) 3584-001
27: RETAINER,BEARIN
28: SCREW
[sCREW]
29: GEAR,KICK START
(NT:27) 490136-001
30: TRUST WASHER
31: THIRD PINION CI
33: SPACER,ENG SPRO
34: 4TH DRIVE GR CI
35: O RING,D:1.9,ID
Styka Ci ?
