WITAM. ROZRUSNIK KRECI ZA KAŻDYM RAZEM PODOBNIE. SILNIK OWSZEM DUŻY ALE OGLADAŁE INNE VICTORY I ODPALAŁY PRAKTYCZNIE OD OBROTU. TUTAJ ZAŁĄCZAM POMPĘ KZAPAŁAM, ROZRUSZNIK KRĘCI I KOMP ODCINA, DRUGI RAZ TO SAMO I NIC, TRZECI RAZ PALI OD OBROTU..RÓWNO ,. NIE MA SYTUACJI ŻE PRÓBUJE ZAPALIĆ , ZE COŚ ŁAPIE. INNYM RAZEM PRZY DRUGIM ZAKRĘCENIU ODPALA.JAK ODPALI PRACUJE BARDZO ŁADNIE. JAZDA FENOMNALNIE. WKRECA SIĘ MOMENTALNIE.ŚWIECE SPRAWDZAŁEM CZYSTE ,JANE,ŁADNIE WYPALONE.AKU Z GÓRNEJ PÓŁKI TYPOWO POD TEN MODEL(BO SPECYFICZNE WYMIARY).I TERAZ CZY TO PROBLEM NP PALIWAM, W SENIE POMPA, ZAWOREK REG CIŚNIENIA ? CZY MOŻE ZBYT MAŁE NAPIECIE ROZRUCHOWE IDZIE( BO MAM WRAŻENIE JAKBY TEN ROZRUCH BYŁ TROCHĘ CIĘZSZY NIŻ W JAPOŃCU...CHYBA ŻE ZE WZGLEDU POJEMNOŚCI). ZASTANAWIAM SIE RÓWNIEŻ CZY TEN MODUŁ"DYNAJET" NIE ROBI JAKIEGOŚ PROBLEMU ....
TO ZE DUZY SILNIK I MUSI OBRÓCIĆ TO OCZYWISTE...ALE NIE ŻE MUSI KRĘCIC AŻ ODPALI ZA DRUGIM CZY TRZECIM RAZEM.
